Hello everyone,
I have a question regarding short ED conditions and their substantiation. The following is the 3-step method generally accepted:
1. First, one either looks up or computes the bearing strength of the fastener/material combination using the SRM tables or the bearing formula Fbru * d * t, respectively. Note the fact that the SRM tables are based on 2D ED and that the Fbru used in the bearing formula in this step is Fbru at 2D ED (some people use the Fbru at 1.7D ED).
2. Then, one computes the shear-out allowable based on the short ED condition (for instance, assume our discrepant fastener only has 1.5D ED). Shearout formula used is Fsu * 2 * t (ED - 0.383D) where Fsu is the fastener's.
3. If the value in (2) is greater than (1), the short ED of 1.5D is acceptable for strength.
My question is this:
The calculation in (1) seems to be in error since Fbru in the formula "Fbru * d * t" is a function of edge distance. Likewise, the SRM tables are only valid for 2D ED; with a shorter ED yielding a smaller allowable. However, in step (1), we looked up (or calculated) the bearing allowable based on the ORIGINAL joint configuration with an edge distance of 2D, when in reality our actual discrepant fastener possesses only 1.5D ED. This shorter ED of 1.5D will incidentally yield a smaller bearing allowable than the one looked up or computed in step (1).
This renders the comparison in step (3) invalid and illogical, since you're now comparing a shear-out allowable (albeit based on the shorter ED of 1.5D) to an allowable that's now lower than the original design joint bearing strength as explained in the previous paragraph. Since a joint is inherently designed to be bearing-critical, you've just demonstrated that the short ED condition yields a bearing allowable that's now lower than originally designed, regardless of the new shear-out value calculated in (2). This cannot be acceptable for strength!
Could you please shed some light on this? If the above procedure is not correct, could you please describe your method of substantiating short ED conditions?
Thanks,
A confused Alex
Thanks,
A confused Alex
