I have a problem were a stainless tube (.011 thick) is plated on the inside with copper (.002). I have a heat source generated inside the plated tube and I am trying to see how hot the internal parts are getting? Just a note the stainless pipe has heat sink disks brazed to the outside at a specified pitch which are held at a constant temp and the internal parts consist of another assembly that will be omitted for now to simplify the problem. So to resume I basically have a stainless pipe with copper plating on the inside. I have placed a heat flux on the copper and held the outside surface of the stainless steel at constant temp. I have modeled the assembly as two tubes with the outer tube representing the stainless pipe and a thinner tube representing the copper plating. I then used a bonded contact and meshed the outer tube with bricks and the inner tube (due to its thin thickness) with shell elements meshed using midplane. When I run the analysis no heat is transferred through the copper into the stainless tube. I am not sure why? Did I not fill in a parameter some were for the shell elements? If I use brick elements for the inner tube the mesh is very poor even at fine settings but heat does transfer through (do not trust the results with this mesh). Any help would be great.
Steve
Steve
