Angsi
- Feb 17, 2003
- 83
Will someone please advise me if Flow Induced Vibration Analysis for shell and tube heat exchangers is performed as a routine mechanical calculation for the equipment or if it is performed only with a special request? Is a specialist engineering contractor required for this "highly complex" analysis?
Anyone with the experience, please also share with me how the results affect exchanger design i.e. besides additional/relocation of baffle support plates for the tubes, are there normally any other recommendations made?
Has anyone got the experience of designing a gas cooler shell and tube exchanger with slugging problems? Besides relocating the inlet pipe away from the tube/impingement plates, what other engineering precautions were taken?
Thanks in advance.
Thanks in advance.
