BodyBagger
- Feb 23, 2007
- 459
Hello all,
I do not do much in the way of sheetmetal so I would like to get some proper methods input for a simple part. I have a 10AWG flat plate about 18 inches wide that will have left and right flanges bent down 90° 1" in from each side. In the fixed face region I need to put some drilled holes and some tapped holes. Should the holes be put in prior to bending and should they be dimensioned from the edges before bending? Or should they be put in after bending and then dimensioned from the now bent face?
Thanks in advance,
BB
Thanks in advance,
BB
