Op
How many, quantity?
Low volume 10 pcs, or 10000 parts.
This is a great brain teaser.
My thoughts and opinion.
Thus a very small part. I would first of make a new design.
OK but if you are set on this.
It will require developing.
Trial and error to allow for spring back.
A two or three stage die. Reason the leg
Pushed into the center.
Create the two small bends on b each end.
Then the large radii
Then bend the inner leg.
Depending on hardness, or tensile strength.
For small lot a small fixture with removable pins. Similar use for bending tubing.
HTH
