sourkraut
Materials
- Mar 29, 2007
- 16
I have a part that I have designed as a solid part using the swept blend tool. The part is a square 422mm X 422mm that transitions into a 122m diameter hole. The distance between square and hole is 150mm.
So it is a funnel that goes from a square to a circle.
It was constructed originally as a solid and then the shell tool was used.
The current problem is that I would like to turn it into a sheet metal part and have calculations for the flat part done by Pro e.
The collar around the round part can be separate and welded on afterward.
I am not sure where to start, I have not used the sheet metal feature before.
any known tutorials would be great to on the sheet metal feature!
Thanks in advance
Thanks in advance
