The majority of our products are based on large weldments that we use NX sheetmetal to design and create the flat patterns. Sheet metal to us can be up to 25mm thick, and in many cases we need to add chamfers to edges which are basically weld preps. We have recently started seeing issues cropping up where the flat pattern is not forming properly, as per the attached model. This means that we can no longer create the flat pattern in the model file because the flat pattern will always jump to the last feature, instead, we are returning to an old method we used to use where we WAVE linked the part at a time stamp before the chamfers were created in the Master Model drawing and creating the flat pattern from the wave linked body. It works, but its a bit of a pain in the rear doing all these extra steps. Should NX be able to handle features like these considering that chamfer is presented as a feature on the sheet metal toolbar?
Best regards
Simon NX7.5.3 - TC 8
Best regards
