BR0
- Nov 10, 2010
- 51
Hi All,
I've read a lot of the threads about shear flow and designing bolts or welds and I haven't see this topic addressed so perhaps it isn't an issue.
I was wondering about the moment of inertia to be used for calculating deflections. In general, can you use the full cross section moment of inertia when using intermittent welds. I imagine I'm missing something easy here.
If you have a built-up I-beam and used full pen welds for the full length of the beam span, it does seem obvious that a full cross section moment of inertia could be used.
On the other-hand if you have a fairly long span beam and a moment controlled section, and you use VQ/I and have intermittent welds wouldn't the section deflect as if it has a changing cross section. As an example if you used 1" of full pen weld at 12" on center, would the beam need to modeled for deflection as if it were made of three independent plates in the gaps and only as a composite section in the weld areas?
A beam I'm designing right now has a 22" deep web and 8" wide flanges. When using VQ/I, the beam only requires a 1/4" weld at 12" O.C between the web and flanges. It somehow doesn't "seem" correct to use the full cross section for this
