sorin84
Automotive
- Aug 29, 2012
- 4
Hello, I am new in vibration domain and I am looking for some information.
I have to perform a random vibration test:
Hz (m/s^2)^2
10 10
100 10
300 0,51
500 5
2000 5
R.M.S. acceleration 96,59(m/s^2)^2
Sigma clipping 3
Necessary force to perform this test is: 66938 N (for 3sigma and my test setup load - it was calculated by the vibration control software).
Available shaker force: 90000N.
I start the test at -6 dB, after that at -3 dB and after at 0 dB. When the acceleration level is at 0 dB I hear some sounds from inside of power modules of shaker amplifier. The sounds is like when a switch is turned on and off, on and off - or a non engineering description- the sound is like when pop-corn is donne. I take a look inside of a power module and I didn’t see any switch.
Can somebody tell me:
- if this sounds are the effect of the acceleration clipping;
- if this sounds are the effect of the test setup load ;
- if a test require 75% or more (but less than 100%) of shaker availability for one of the following parameters: displacement, velocity, acceleration, force, for how many hours the shaker can work in this conditions?
Hz (m/s^2)^2
10 10
100 10
300 0,51
500 5
2000 5
Sigma clipping 3
