Shaker load question
sorin84
Automotive
RO
Hello, I am new in vibration domain and I am looking for some information.
I have to perform a random vibration test:
Hz (m/s^2)^2
10 10
100 10
300 0,51
500 5
2000 5
R.M.S. acceleration 96,59(m/s^2)^2
Sigma clipping 3
Necessary force to perform this test is: 66938 N (for 3sigma and my test setup load - it was calculated by the vibration control software).
Available shaker force: 90000N.
I start the test at -6 dB, after that at -3 dB and after at 0 dB. When the acceleration level is at 0 dB I hear some sounds from inside of power modules of shaker amplifier. The sounds is like when a switch is turned on and off, on and off - or a non engineering description- the sound is like when pop-corn is donne. I take a look inside of a power module and I didn’t see any switch.
Can somebody tell me:
- if this sounds are the effect of the acceleration clipping;
- if this sounds are the effect of the test setup load ;
- if a test require 75% or more (but less than 100%) of shaker availability for one of the following parameters: displacement, velocity, acceleration, force, for how many hours the shaker can work in this conditions?
Each power module of the amplifier have a green (OK) and a red (not OK) LED. For the vibration test described above the green LED was ON permanent.
It's only 1 g rms, which should be within the range of any reasonable shaker. How heavy is the UUT?
TTFN
faq731-376
7ofakss
But his units were (m/s^2)^2
TTFN
faq731-376
7ofakss
Errr...then 3.3 grms? Agree hard to figure out with the units as written.
Given his stated force requirement, it seems likely that someone glitched a decimal place. 22300N/10g = 227kg, which seems like a plausible number, but it's shouldn't be anywhere near 10g, unless they doing some sort of accelerated life test.
TTFN
faq731-376
7ofakss
The test has to be perform on the slip table. Total weight of all test setup - including moving element of the shaker is aprox. 230 kg.
OK, someone needs to check the units, the numbers given are not consistent with each other nor with reality. The PSD given, if the units are correct, result in about 98 m/s^2 rms, not 98 (m/s^2)^2, or about 10g rms, which is consistent with the loading on the shaker
Again, 22300N/230kg = 9.9g rms, which is a very severe vibration level.
Is your UUT top-heavy?
TTFN
faq731-376
7ofakss
I'm sorry! The unit for rms value is (m/s^2).
Slip table + copling element + thermal barrier + moving elemet + fixture + screws + UUT's = 230kg
But, is it top heavy? A standard slip table is prone to rocking if the UUT pushes the CG too high
Have you contacted the manufacturer?
TTFN
faq731-376
7ofakss
