In our refinery we have three towers to strip acid water. The pumps at the bottom of these towers pump the stripped water back to the plants. The suction pressure is 4,3 kg/cm2 and the discharge pressure is 27,5 kg/cm2. One of these pumps has failed frequently by shaft rupture, the other ones never had this kind of failure. The pump that has failed is a different model from the other ones. The rupture is caused by fatigue and the frequency is approximetely one by month. This pump has a very narrow impeller (three times more narrow) then the other pumps to the same flow. Does someone has any experience with this kind of failure?
