I am involved in the design of a device that utilizes a rotating shaft driven by a T-head gearbox to two driven devices on each end of the shaft. All three of these devices are mounted to a common plate. Note that the shaft rotates slowly. Approx 100 rpm. The shaft diameter is approx 1/2"... plate ground flat... This is a small benchtop machine and the devices weigh less then 20 lbs.
The discussion point is regarding the "need" for specifying a method to align the two driven devices to the T-head gearbox (and shaft). One recommendation is to "simply" torque all mounting fasteners as a group once fully assembled. Effectively using the shaft to align the driven devices.
Ultimately the debate is:
Does there need to be any specifics on the face of the drawing to ensure the shaft alignment process takes place as described above? Or are there industry standard / millwright standards etc that can be assumed will be followed.
I realize I am posting this in a drafting forum amongst engineers. I expect an overwhelming "we need to define everything," and "never assume." However I am playing a little bit of devil's advocate and curious if the task doing this sort of assembly should carry the expectation that qualified assemblers would just know to ensure alignment via whatever background training (qualification) they have. Similar to tightening lug nuts or head bolts.
I have spent the better part of the day trying to find examples (online) of machinery assembly drawings to make a case either way. However as would be expected, companies don't have their proprietary documentation readily available.
Looking for feedback from other industry professionals. Thanks.
-Dustin
Professional Engineer
Pretty good with SolidWorks
-Dustin
