Sewing surfaces to create a solid
acciardi
Computer
Jun 6, 2006
143
Hello - can comeone please refresh my memory...
If I have a closed volume formed by various surfaces that I have trimmed, sewing the surfaces together should create a solid, correct? There should be no further operations necessary, right?
I don't currently have access to a seat of NX to test this, but I'm trying to mentally bone up for a potential job interview.
Thanks in advance,
Ed
That is correct, if the sheet bodies (surfaces) enclose a watertight volume of space, sewing them together will result in a Solid body being created.
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Sewing closed surfaces results in a Solid, Provided your surfaces are withing the sewing tolerance and the Preferences>Modelling>Body Type is set to Solid.
AK
NX 3.0.5.3
Actually, if the surfaces encloses a volume, the result will be a Solid irrespective of the Solid/Sheet Modeling preference setting.
John R. Baker, P.E.
Industry Sector
Cypress, CA
And if most of the sheets sew together and you don't end up with a solid, you can look for sheet boundaries with the 'examine geometry' tool (in the Analysis menu) to see where the problems are.
