How do you change the settings UG uses anytime you start a new model? I am specifically looking at changing the palette to a customer specific one so that when you use the command "create new component" under assemblies, it uses the customers palette instead of the default one. I would like to make the new palette the default one for all new models while I am doing work for this customer also. Thanks for the help in advance.
