setting "X" and "Y" reference points
  • Thread starter Thread starter rullan
  • Start date Start date
R
rullan
Guest
Is there a way to establish a coordinate position where X and Y = 0, so that you can simply reference dimensions from there?
not sure what you mean.
dimensions can be converted to ordinate in the drawing mode.
I think I stumbled onto the solution. You're right, I can set the linear dimensions to ordinate.
You can dimension from a coordinate system. You can put a coordinate system where ever you want.
