vonsteimel
- Oct 19, 2010
- 132
Greetings,
The company I'm working for has been in a product development stage since the 70's. In the past decade the product has stabilized (thanks to the development) and we are ready to move from a fab-shop environment to manufacturing/production. We I started, we only had a very simple drawing system. Basically a 4-digit number would be given to each part. Then in a "drawing cabinet" you can look up that number to see if there is any drawing or information under it. All sheets are A size so they fit in the cabinet.
However, with each part there is basically 4 different sets of data. I'm trying to figure out a simple system to track & reference the different types of data to each part #. Lets say I have part# 5555; 5hp briggs & stratton engine.
-Inspection/receiving drawing: How to inspect the engine when we receive it to make sure it is in working order & we got everything we ordered. And how to break it down (if necessary) for inventory/storage
-Fabrication/Modification: Details what has to be done to the engine to prepare it for use/installation (i.e. drilling mounting holes, sealing off terminals, mounting airbox & exhaust.etc)
-Manufacturing processes: How to go about the Fabrication/Modification process (i.e. Order of operations, How to use the tooling, time limit.etc)
-Installation/Assembly: How to install the engine
Now we're pretty low budget at the moment. We only have about 15-20 employees & are set up in a cellular mfg layout. -- When I arrived, -Fabrication/Modification drawings were about all that existed. I am instructed not to use alpha-numeric system. Perhaps I was thinking of using a dash number (5555-1, 5555-2, 5555-3, 5555-4) where 1 = Inspection/receiving drawing; 2 = Fabrication/Modification .... and so on. Then each -# could be kept in the corresponding cell.
How do other company's handle this? Our solution must be very simple for now.
Also, we are using our own mfg software that we have been developing since the early 90's (when there wasn't much on the market) which is dysfunctional at the moment. This is largely why we use a "paper" drawing system & cabinet. (We are also using an index-card "kan-ban" inventory system). We're exploring other software options at the moment but that is for another discussion.
I need ideas about how to handle the drawing situation. Any input will help.
Thanks,
VS
Thanks,
VS
