g.alshamsi
Hello all, I have a general question regarding general contact using ABAQUS/Explicit
I'm modeling a shear wall assembly made from several shell parts (S4R; beams/columns/steel sheet). I've positioned the parts in the assembly with an initial gap between each part equal to half the shell thickness. After submitting the job, the sta and msg files reported the following errors:
218 node-face overclosure(s) left unresolved and will be stored as offsets.
To help identify the nodes involved in the overclosures a node set
InfoNodeUnresolvInitOver has been created. Check the message file for more
detailed information.
Abaqus/Explicit will attempt to resolve 442 initial node-face overclosure(s).
Abaqus/Explicit will attempt to resolve 12 initial edge-edge overclosure(s).
From my understanding, the general contact algorithm solves initial overclosures using strain-free adjustments. However I'm not confident about the quality of the simulation with these errors. From the literature and the manual, the general recommendation is to define a step after the initial step to establish contact. I'm not quite sure how to achieve that. Do I position parts with a significant gap between them then define a displacement BC to ensure that contact is established (by pushing them towards each other)? Keep in mind that contact is achieved mainly through connector elements (to simulate screws).
Any help would be be appreciated, I've been stuck on this problem for sometime and I'm running out of ideas. If anymore info is needed I'll gladly provide it.
Thanks!
Thanks!
