mirghaffari
hi every body,
we want to select the booster pump to supply the required NPSH for main pump.
main pump:
NPSHa = ATM
NPSHr = 5bar
suction pressure = ATM
Discharge pressure = 37 bar
what shall i considere to select the booster pump for this application?
1- i think that the flow of booster pump shall be equal to main pump, what a bout the head of booster pump?
2- when these two pump operate in series, can we sure that they work in compatible with other?
3- is it possible we select the screw pump as booster pump since our main pump is centrifugal?
regards,
main pump:
NPSHa = ATM
NPSHr = 5bar
regards,
