My Ansys 7.1 model consists of two different types of elements.
The first type is assigned a material property 1, the other - mat2. I used the utility menu option: Select-By Attributes-Elements Attributes-1 to display only the elements having material properties 1. Next, I wanted to select a part of displayed elements that, in this particular case, constituted a portion of the model I was interested in. I was searching for the menu driven options like: select-by box/circle/polygon and then hide/blank/erase/remove from the screen all selected elements but there was none ( or I did not find it).
How do you do it in Ansys? I am relatively new to the program. Maybe a command line option exists?
Thank you,
Thank you,
