MechEng176
Hi Everyone,
Been following eng-tips for awhile now and finally made an account to ask a question. Junior mechanical engineer here working on my first project. I'm working on a project where I have to pump 500m3 of oil(or any other hydrocarbon) from tanks into a pipeline operating at 500psi in 1hr (so 8m3/min). For the setup I have tanks, centrifugal pumps(to feed the PD pumps), positive displacement pumps, 60m of 4'' pipe, a metering skid (rated for 10MPA/1450psi), and then the pipeline (which has the same fluid flowing through it at 500psi).
I used a head loss calculator from attached picture)and have determined that at the rate the fluid will be flowing, there will be a pressure drop of 140psi and head loss of 480ft through the 60m section of pipe.
When speccing the pump, I was told to look for a pump that will put out 10MPa at 8m3/min.
So my questions are:
1. If I add the 140psi drop to the lines 500psi operating pressure I get 640psi. Does that mean I need a pump that will put out atleast 641psi?
2. Will the 641psi pump be able to push my fluid at 8m3/min into the pipeline which is at 500psi?
3. Where does hp come into pump selection?
4. Where does the head loss of 480 feet come into play?
5. Looking to order the Flow of Fluids Through Valves, Fittings, and Pipe TP410 by Crane. Yay or Nay? Any other book recommendations?
