Select circles in drawing view 1
TiagoFigueiredo
Industrial
PT
I want to select all circles inside a view in drawing.
Any idea to do it. I tried the find command, but all constructions inside a view are called "Generated item", So it's not easy to create a filter.
Tiago Figueiredo
Tooling Engineer
Youtube channel:
Just a wild idea: one by one in selection and try to hatch them or measure the radius [peace]
It's wild enough. I try this old method, but select more than 200 holes, mixed with other circles that they aren't holes, is killing me. I was trying an easy way...
By the way, I found this.
But I don't have the required license...
I need an easy way to select the holes in drawing....
Tiago Figueiredo
Tooling Engineer
Youtube channel:
what do you want to do with the selection?...
In View-properties you can add Center Line as Dress-upp--will that help?
regards,
LWolf
I Still didn't found an away to select the circles in the view, and retrieve the dimensions . I thought before that it would be an easy task, but as always, the is always thereabouts...
I have all of the needed holes with technological results. Is possible to retrieve all the information from the 3d and insert the information in drawing, like coordinates, and type and dimension of hole?
Tiago Figueiredo
Tooling Engineer
Youtube channel:
