2d Catalog Components orientation in drawing view
Rich68
Industrial
When placing a 2d components from a catalog into a CATDrawing view, it uses the orientation of the view. How do I get Catia to place the objects normal to the screen...zero rotation? Is there a CATSetting for this?
No such setting AFAIK.
You can place components on the main view, but then when a view moves you have to move them manually.
There is definitely a setting, because all was working and then one day the symbols being placed on views were not normal to the screen. Itis as though a CATSetting or something corrupted. Just trying to find in Options, but having no luck.
There's a setting that makes component size independent of view scale, but not rotation:
Tools - Options - Mechanical Design - Drafting - Annotation and Dress - Up-2D Component - Create with a constant size
Are you sure that back in the day when "all was working" components were placed on a view, not on a sheet?
Do you have any other PCs available where components are still being placed differently?
