Hello all,
The new 2007 CBC which is based on the 2006 IBC provides requirements for performing seismic site response analysis. The 2007 CBC actually references ASCE 7 for the details of the requirements.
A big problem I see with the ASCE 7 recommendations is that they require you to develop the response spectrum and time-histories using the MCE (2475 year return period EQ), then to scale the response down by 2/3 to come up with the design response spectrum and time-histories.
The problem is the site response you obtain by using the MCE input ground motion will be very different from what I would obtain by using 2/3 of the MCE ground motion. In using the MCE input ground motion, most all saturated sandy sites will liquefy and will have a base-isoltaed type of response after the liquefaction occurs. This is because the MCE PGA is at least 0.6g at least in my area of Southern California. I am using a non-linear effective stress code for the analysis.
Scaling this response down by 2/3 will retain the characteristics of the base-isolated type of response.
I believe the input ground motions should be based on 2/3 of the MCE, this way the estimated site response would be more represetitive of the site. But the ASCE 7 appears very clear that the input motion should be based on the MCE.
Anyone have thoughts on this topic?
