Seismic force on elevated tank foundation
Andrewstructure
I need to calculate the seismic force on an elevated tank foundation (deep concrete caissons/drilled piers).
I am analyzing the 7' diameter x 10' tall hazardous liquid waste tank as a "non-building structure' per ASCE 7-05 chapter 15.
I am assuming that it is rigid and 15.4.2 applies. The actual tank was designed by others.
My problem is that the base shear calculated (eq 15.4-5) is less than that calculated by ASCE chapter 13 (eq 13.3-1), so I am wondering if I made a mistake.
Bednar "handbook of Pressure vessels" has a section on it for elevated vertical tanks, however, his method is not a current one but the results should be closely similar.
What acceleration value did you get to determine the seismic load.
I believe ASCE and IBC describe these as inverted pendulum structures and have very particular requirements.
