Dave,
I think you are referring to the linearity calculation, and then the calculation of the theoretical x-intercept (offset). I think he was just asking about the way ECU manufacturers refer to this. In my experience, it's different than how injector manufacturers normally think of it.
GordonLee,
In the world of programmable ECU's, injector latency, sometimes referred to as offset, is the term that is used that correlates to opening time of the injector. (To an injector design engineer, Opening time is different than offset, as Dave points out. In the SAE spec he references, it defines both, and how to calculate them. In my experience, the ECU manufacturers use this term interchangeably. Latency is really "opening time" = the time elapsed from the start of the logic pulse, to the start of fuel delivery from the injector. In a port injector, this is a function of many design parameters and calibration spring load in the injector used. It's also directly affected by the voltage supplied to the injector by the driver and the operating delta pressure across the injector. Peak and Hold driven injectors are less affected by the battery voltage, compared with saturated drive injectors, but they are still affected.
For example, when I calibrated my 3.8L Porsche club racer with a MOTEC controller, I needed the effective opening time at the dynamic calibration point for a range of battery voltages from 6-16V. I got opening times measured at 1V increments, and used that for programming the look-up table in the ECU.
Dave is correct about closing times being very important in having good linearity. Closing time is not as important to the controller, however, as it primarily impacts the effective duration of injection. (i.e. fuel keeps being delivered after the logic pulse ends) I say it's "not as important" because most ECU's now have so much control authority than they can adjust (lengthen or shorten) the pulse width being commanded of the injector by a large amount, and the effective duration of injection is sort of lost in the noise, as long as it's not excessive. Modern ECU drivers for high impedance injectors employ a zener diode to shunt the flyback current, which allows the magnetic field to collapse very quickly after the drive pulse ends. Assuming reasonable spring loads for most production injectors, most port injectors have closing times in the .4-.7ms range. The important part is that it needs to be CONSISTENT, in which case the ECU's capabilities mask it, making it SEEM unimportant. Opening time, or latency, is more important to the ECU from a timing perspective, to get the fuel shot delivered at the appropriate time. Since most port injectors have opening times in the 1-1.5ms range, this is more critical to overall timing.
I hope that helps.
-Tony Staples
