I understand, that in, for example, inline 4 engine, when pair of piston (1 and 4) goes down from TDC, other pair goes up from BDC (2 and 3), that pair, which goes down, moves faster and create secondary imbalance, at 90deg secondary balance force curve changes direction, because, that pair which goes up from BDC (2 and 3), now is going faster nor 1 and 4 pistons, because from 270deg to 90deg is more way which piston must travel. And I understand, that when pistons is at 90deg, center of gravity is lower, and when pistons is at TDC and BDC, center of gravity is higher. But when is only one cylinder in engine, and when crankshaft turns 90deg from TDC, secondary balance curve also changes direction, like in inline 4 engine, but there is no other pistons, which goes upward faster, when that cylinder goes downward slower, it's only one cylinder, and I don't understand, why, when is only one cylinder, secondary balance curve change direction at 90deg and at 270deg? In single cylinder engine, when piston goes down, from TDC to BDC, all vertical forces moves down, yes? And when piston goes up, from BDC to TDC, all vertical forces goes up? If yes, then why secondary forces change direction at 90deg and 270deg in single cylinder engine? Thank You for Your answers, it's really interesting to me
