SE V20 - How can I change the partlist and make it default
RAMviking
NO
Is there a way to change the default partlist.
Solid Edge V19
SP 7
Are you talking about the defaut choice from the pulldown menu when you want to insert the part list?
If so then the only way I can think of is to rename your different part list to have them sorted by numerical or alphabetical order. But I haven't check if the pulldown actually sort them or if it just show them in the order they are created in the draftlist.txt file.
Patrick
