Screw thread FIM callout 1
craigmj
Hello All,
I recently designed a custom screw with a 3mm X .5 thread. This thread is formed by cold rolling and is 1/4hard SS. Thread mates with a nickel plated brass insert that is ultrasonically welded into plastic.
Keep in mind I am new to this screw design stuff...
Turns out when I get the parts that the thread was rolled on at an angle (warbles when you screw it in). This causes some serious problems with force distribution on the threads of the insert and basically cases the inserts to strip out after only a few insertions.
My question is this. Wouldnt one think that if you call out a particular thread on a shaft that the angle at which you can cut that thread (or form it in my case) on the shaft would be limited to some range...inherently?
Anyhow, the vendor comes back to me saying that I never incuded a "FIM" number on the drawing (full indicator measurment) and that although the threads on the screw are at an angle we have no recourse to return them. The FIM measurement on the screws I recieved was 0.070...thats huge if you ask me!
Can anyone tell me how they deal with this issue on a drawing? Is FIM a standard thing to call out? Is what I am experiencing here normal or am I getting "screwed"?
Thanks!
Craig J
ringman,
Absolutly. I got lucky.
