HI All,
I am also busy with a new hydrogenation pilot plant processing refined vegetable oil, with the aim to reduce the iode number by a factor of 10, before further processing downstream.
The reactor system is dimensioned, but I am strugling with the hydrogen and nitrogen gas feed to that reactor. The Nikkel catalisator has to be activated (reduced), and that requires heating up the catalisator to 180°C with a mixture of 10% H2 and 90% N2, then slowly increase the H2 and decrease the N2 concentration, and end the process with a 95% H2 and 5% N2 gas mixture. That gas mixture is being injected into the reactor, after passage into a heat exchanger to bring it to 180°C, from their respective evaporation temperatures, starting from liquid bottle phase.
my problems are :
a) H2 and N2 gas temperature in the downstream piping after their respective evaporation, prior injection into the heat exchanger bringing it up to 180°C with thermo oil. I need to determine the delta T needed for that heat exchanger (180°C - (gas temperature)), when considering outside winter temperature equal to minus 10°C (windchill factor not included due to insulation over pipe).
b) is flowcontrol or pressure control the main control system?
H2 flow rate = 18kg/h liquid to be evaporated
N2 flow rate = 1000kg/h liquid to be evaporated
c) how does the gas street to achieve this regulation and gas mixing look like?
d) what type of metal do I use? Copper, steel , SS (I think of using SS304L, my boss' recomendation, so no budget problems)
e) are there turn key suppliers on the market?
f) the suppliers of H2 and N2 aren't forthcoming, and I suspect they want to keep their hands off this pilot plant and it's eventual problems.
any input appreciated.
thanks.
