RogerSAM
- Feb 20, 2024
- 4
Hello everyone,
I have a specific case that I needed some insight on since I am a relatively new engineer who is still learning.
We conducted a string test to check the response of a lube oil system that consisted of two pumps - 1 main and 1 standby. The main turbine driven pump was manually tripped and the system transient response during the stand-by's cut-in period was verified. The test was successful and header pressure did not drop to alarm levels during the test.
Now the question is around 5 minutes or so before the test, both the pumps were operational. The stand-by pump was then shutdown to conduct the test. My senior is telling me that since the stand-by pump was just recently shut off, it doesn't simulate the real behaviour because during the normal operation, the stand-by would be off for a long time. So although in the test, it generated pressure fast, it wont necessarily do it in the actual real world scenario. He's talking about breaking of the inertia of the fluid etc. that just doesnt make sense to me.
Is he right?
Is he right?
