Scale in Note. 1
tighthead
NZ
How do we include the scale of a view in a note on a draaawing (linked)?
SW2005 sp0.
No thats not it, thread559-155291
Thats basically the standard SW help.
When you have a standard view (not detail etc).
We put multiple parts on one sheet & sometimes scale them differently, how can we show the scale for each part on the drawing in a note:
We have good reasons to do this.
tighthead,
Here is some code I wrote awhile back that may help you.
Regg
Code:
Option Explicit
Dim swApp As SldWorks.SldWorks
Dim swModelDoc As SldWorks.ModelDoc2
Dim swDrawing As SldWorks.DrawingDoc
Dim swSelMgr As SldWorks.SelectionMgr
Dim swView As SldWorks.View
Dim swNote As SldWorks.note
Dim swAnnotation As SldWorks.Annotation
Dim swSelection() As Object
Dim ScaleRatio As Variant
Dim ViewCorners As Variant
Dim SelectionIndex As Long
Sub main()
    'attach to SolidWorks
    Set swApp = Application.SldWorks
    'get active document
    Set swModelDoc = swApp.ActiveDoc
    'check for document
    If swModelDoc Is Nothing Then
        MsgBox "No active document.     ", vbOKOnly + vbCritical, "Label View Scale"
        Exit Sub
    End If
    'check if document is drawing
    If swModelDoc.GetType = swDocDRAWING Then
        Set swDrawing = swModelDoc
    Else
        MsgBox "Active document must be drawing.    ", vbOKOnly + vbCritical, "Label View Scale"
        Exit Sub
    End If
    'get selection manager
    Set swSelMgr = swModelDoc.SelectionManager
    'check if anything selected
    If swSelMgr.GetSelectedObjectCount = 0 Then
        MsgBox "No views selected.    ", vbOKOnly + vbCritical, "Label View Scale"
        Exit Sub
    Else
        'save selections
        ReDim swSelection(1 To swSelMgr.GetSelectedObjectCount) As Object
        'check if selection is drawing view
        For SelectionIndex = 1 To swSelMgr.GetSelectedObjectCount
            If swSelMgr.GetSelectedObjectType2(SelectionIndex) = swSelDRAWINGVIEWS Then
                Set swSelection(SelectionIndex) = swSelMgr.GetSelectedObject5(SelectionIndex)
            End If
        Next
    End If
    'analize selections
        'check if selected object is view
        If swSelection(SelectionIndex) Is Nothing Then
            MsgBox "Selected object " & SelectionIndex & " is not a drawing view.     ", vbOKOnly + vbExclamation, "Label View Scale"
        Else
            'get selected view
            Set swView = swSelection(SelectionIndex)
            'get view scale
            ScaleRatio = swView.ScaleRatio
            'get view corner locations
            ViewCorners = swView.GetOutline
            'lock view focus so note will move if corresponding view moved
            swView.FocusLocked = True
            'create note
            Set swNote = swDrawing.InsertNote("Scale " & ScaleRatio(0) & ":" & ScaleRatio(1))
            'set note angle
            swNote.angle = 0
            'set note is balloon to no
            swNote.SetBalloon 0, 0
            'get note annotation object
            Set swAnnotation = swNote.GetAnnotation
            'set note leader to none
            swAnnotation.SetLeader2 False, 0, True, False, False, False
            'locate note 10mm right from left edge and 5mm below from bottom edge of view bounding box
            swAnnotation.SetPosition ViewCorners(0) + 0.01, ViewCorners(1) - 0.005, 0
            'unlock  view focus
            swView.FocusLocked = False
        End If
    Next
    'refresh graphics screen
    swModelDoc.WindowRedraw
End Sub
I apoligize for my misunderstanding of your post. There is one possibility to make a linked note, but it's sort of hoky, and you may not want to do it. You would have to make each view either a detail view or auxiliary view of a view that's off the sheet printable area. You would also have to manually line up the different views of each part. Go to Tools->Options->Document Properties->Detailing->View Labels and change the view label format to show only the scale.
