MadMango
- May 1, 2001
- 6,992
SW05 Sp4.0
I'm having trouble scaling a sketch to the proper size. I received an AutoCAD drawing from a customer, and when I copy the sketch into SW, the scale is off. A dimension that is 249mm in the 2D drawing comes in at 24.9 inches in the SW sketch. I've gone through Help, using Tools>Sketch Tools>Scale or Copy without any affected change. Any pointers for scaling a 2D imported sketch?
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read faq731-376 to make the best use of Eng-Tips Forums?
