I am not A SAP user, but Vertical Rigid Links may work enough. I am sure your framing is a little more complex than what you are showing. If the upper beam will not remain flat on top of the lower beam due to bending, you will still get some slight torsion from the point load reaction at the inner edge of the lower beam.
