Sap2000 - Inclined Beam
Thaereid
Dear Friends,
I do a model for an inclined steel frame, but the deflection limits were not checked, although I requested program to consider deflection from the steel design preferences, is there any way to automatically check deflection limits for an inclined beam?
Appreciate any illustration.
Thaereid, if you select your inclined steel beam, you should be able to use Design menu> Steel Frame> View/revise overwrites to specify deflection limits. If the program doesn't perform those checks during design, send your model to CSI's tech support and ask them to see what's going on.
