SAP2000 API - External Analysis Results 1
martinrexfowler
GB
Has anybody tried the API functionality to set external analysis forces to a model?
The code is fairly simple and it's returning that the forces have been correctly applied, however I can't then see any forces in the corrosponding LC in Sap2000.
I struggled with this issue for a while with no result [banghead]
I would really appreciate some help about it from anyone!
hello
I have a problem in this code.
it is base on the example code of Sap2000v20 in matlab.
I want to get the "modal result". but it seems there are some problem.
please help me.
thanks
%% clean-up the workspace & command window
clear;
clc;
%%set the following flag to true to attach to an existing instance of the program otherwise a new instance of the program will be started
AttachToInstance = false(); % true(); %
%% set the following flag to true to manually specify the path to SAP2000.exe
%% this allows for a connection to a version of SAP2000 other than the latest installation
%% otherwise the latest installed version of SAP2000 will be launched
SpecifyPath = false(); % true(); %
%% if the above flag is set to true, specify the path to SAP2000 below
%ProgramPath = 'C:\Program Files\Computers and Structures\SAP2000 20\SAP2000.exe';
%% full path to API dll
%% set it to the installation folder
APIDLLPath = 'C:\Program Files\Computers and Structures\SAP2000 20\SAP2000v20.dll';
%% full path to the model
%% set it to the desired path of your model
%ModelDirectory = 'C:\CSiAPIexample';
%if ~exist(ModelDirectory, 'dir')
% mkdir(ModelDirectory);
%end
%ModelName = 'API_1-001.sdb';
%ModelPath = strcat(ModelDirectory, filesep, ModelName);
%% create API helper object
a = NET.addAssembly(APIDLLPath);
helper = SAP2000v20.Helper;
helper = NET.explicitCast(helper,'SAP2000v20.cHelper');
if AttachToInstance
%% attach to a running instance of Sap2000
SapObject = helper.GetObject('CSI.SAP2000.API.SapObject');
SapObject = NET.explicitCast(SapObject,'SAP2000v20.cOAPI');
else
if SpecifyPath
%% create an instance of the SapObject from the specified path
SapObject = helper.CreateObject(ProgramPath);
else
%% create an instance of the SapObject from the latest installed SAP2000
SapObject = helper.CreateObjectProgID('CSI.SAP2000.API.SapObject');
end
%% start Sap2000 application
SapObject.ApplicationStart;
end
helper = 0;
%% create SapModel object
SapModel = NET.explicitCast(SapObject.SapModel,'SAP2000v20.cSapModel');
%% initialize model
ret = SapModel.InitializeNewModel;
%% create new blank model
File = NET.explicitCast(SapModel.File,'SAP2000v20.cFile');
%%open an existing file
FileName = 'D:/test/s.sdb';
ret = File.OpenFile(FileName);
%% run model (this will create the analysis model)
Analyze = NET.explicitCast(SapModel.Analyze,'SAP2000v20.cAnalyze');
%ret = Analyze.SetRunCaseFlag('MODAL',false,true);
ret = Analyze.SetRunCaseFlag('MODAL', true);
ret = Analyze.RunAnalysis;
NumberResultsp = 0;
LoadCasep = cellstr(' ');
StepTypep = cellstr(' ');
StepNump = zeros(1,1,'double');
Period = zeros(1,1,'double');
Frequencyp = zeros(1,1,'double');
CircFreqp = zeros(1,1,'double');
EigenValuep = zeros(1,1,'double');
%modal result
AnalysisResults = NET.explicitCast(SapModel.Results,'SAP2000v20.cAnalysisResults');
Setup = NET.explicitCast(AnalysisResults.Setup,'SAP2000v20.cAnalysisResultsSetup');
[ret,NumberResultsp, LoadCasep, StepTypep, StepNump, Period, Frequencyp, CircFreqp, EigenValuep] = AnalysisResults.ModalPeriod(NumberResultsp, LoadCasep, StepTypep, StepNump, Period, Frequencyp, CircFreqp, EigenValuep)
%Open Lock
ret = SapModel.SetModelIsLocked(false);
The manual code is worng the step has to be set as 1, 0. ( This relates to the subject of the post which is external analysis results, not extracting information from SAP2000)
Hi, I think you've posted your query under the wrong thread. This thread is about external analysis results, which is when you can create an external laodcase and attribute 'results' to object stations for use in design, as sample code from the API help file as below. The solution to my probelm is the step num has to be set to 1.
'set frame external result forces at case first step
ret = SapModel.ExternalAnalysisResults.SetFrameForce("1", "EXTERNAL", 0, P, V2, V3, T, M2, M3)
