1.Operating buses carrying shift employees through refinery process unit roads.
The shift employees in our Refineries are provided with bus transport for coming to work and going back after shift work. We are currently debating whether it is safe to permit the buses carrying these employees to ply along roads through process areas, so that the employees can be dropped near their place of work. We are not sure whether this is an accepted practice elsewhere internationally. Can you throw some light on the practices in other Refineries internationally in this matter? Are you aware of any non-conventional type of transportation (eg. solar-energized vehicles) being used anywhere for movement of people inside Refinery premises?
2.No. of air changes required for laboratories.
An oil testing laboratory generates lot of fumes during the process of heating the oil for testing. Sometimes gases are also present in the laboratory environment. Window air conditioners do not remove these fumes. I believe there is a practice of changing the entire atmosphere of laboratory every few minutes to sweep away all the fumes, and air-conditioning plant must have the capability to do this. Could you please tell me whether there is an industry standard for this.
3.Location of hydrocarbon gas detectors for LPG tank wagon loading gantries.
In some of our LPG tank wagon loading gantries at marketing terminals, the gas detectors are placed at grade level, while in some, they are placed at the platform level where the loading arms are located. The possibility of LPG leaking out is from flange/swivel joints of rigid loading arms. We would like to standardize location of the gas detectors at the platform level of the gantry. We would like to know whether there are any industry standards for this.
