s7 - 300
flashmem
Industrial
Jun 20, 2005
3
Hello: I am a new member of this forum, i am from mexico. do you know if the port DP of the PLC S7 314C - 2DP is V0 or V1? this PLC is the step 7 series of Siemens
I don't know. If you don't get an answer here, give a quick call to the Siemens tech support guys. I find them to be very good and very helpful.
They're also patient when faced with "stupid" questions.
Bring back the HP-15
I haven't worked with these in a while, but I thought the 314 PLC just had 1 MPI port to connect with the PLC and download/upload and troubleshoot programs. It sound like there are 2 ports on yours, is that true?
I haven't used that CPU, but I have previous experience with S7-315 DP, -316DP & -318 DP ... and in those CPUs, one way to know that is when the hardware is configured through the Simatic Manager ... usually 0 is the default number for the MPI port and 1 for the profibus-DP ... give it a go. There are also plenty of documentation (e-manuals & help topics) in the Simatic manager and in the siemens support site:
Else, call your supplier or directly to Siemens support.
Espero que esta informacion te sea util ...
Buena suerte,
Saludos,
CPUs with order number 6ES7 314-6CF01-0AB0 (firmware 2.0.0) and newer are DPV1. I'm not sure about olders.
Jacek
Do it right or don't do it at all.
thanks,
ray, yes, it has two ports, the second is DP
