.RVT file load to nx11
Ehaviv
Computer
IL
Hi
is there any way to open or bring .rvt file to nx ?
I don't think so, but there must be an easy way to convert the Rivet file to .dwg or .dxf, which can be imported into NX.
Jerry J.
UGV5-NX11
There are some convertors that will do it for you.
trying goggling .RVT to NX and you will see some
Jerry J.
UGV5-NX11
Thank you Jerry.
Do dwg or .dxf are they 3d solid
When opened in nx.
I really don't know if they will be brought in as solids or curves
Jerry J.
UGV5-NX11
Jerry thank you.
From my experience these formats
Are curves only.
3D- dwg can in later versions ( At least NX12) of NX produce good solids.
Siemens has a .rvt->JT converter which can produce solids in some cases. ( It's NOT dependent on the Siemens products in this case, it's all dependent on what Revit exports.)
.dwg has given me way better results than .rvt.
Tomas
Tomas Thank you for this information.
