Rust removal from springs by electrolysis 1
miagre1
Agricultural
GB
I'm removing rust from leaf springs by electrolysis.
The spring is the cathode, the anode is stainless steel, the liquid is a 10% solution of sodium hypochlorite. 5 amp current for around 24 hrs seems to remove the rust.
The question is, is there a risk of hydrogen embrittlement to the spring and a subsequent cracking failure?
Regards George
Yes there is a risk! By making the spring the cathode you are charging it full of hydrogen. Stick to a mechanical rust removal process like grit blasting.
Thank you for the reply swall. :-)
Seems I just was lucky the past thirty years. I will now refrain from the process (and recommending it).
Thank you so much.
best regards George
Well, JK, that beats the crap 'outa 'media blasting'!
Rod
