HI all,
I run into a problem on rupture disc set pressure for a LIN storage tank.
The design pressure of the LIN storage tank is
P=2 psig
I assumed MAWP (Maximum Allowable Working Pressure) equal to design pressure.
MAWP=2.0 psig
Disc rupture pressure tolerance ?P= ±50 mbar (±0.725 psi)
According to our internal set pressure specification,
Minimum Burst Pressure of the rupture disc
BP(min)=1.1×MAWP=1.1×2.0=2.2 psig (operating rate = 80%)
Maximum Burst Pressure of the rupture disc
BP(max)=BPmin+2?P=2.2+2×0.725=3.65 psig
Disc Set Pressure:
BP(nominal)= BP(min)+?P=2.2+0.725=2.925 psig
However, fabricator and system engineering want to set it to 3.5 psig.
Since I am unfamiliar to API 620 tank, any suggestion and comment to that set pressure will be greatly appreciated.
Thanks in advance, John
P=2 psig
MAWP=2.0 psig
Disc Set Pressure:
