I have experienced pitting corrosion of nickel rupture disc protecting anhydrous ammonia pressure vessel. EDS lab test indicates high amounts of chlorine at the pits. The source of the chlorine is unknown at this time. No other elements of any amount are present. Would chlorine cause the corrosion in an anhydrous ammonia gas atmosphere? During installation, water could possibly contaminate the area of the pipe where the rupture disc is installed.
Alternately,would ammonia cause corrosion of the nickel, possibly in combination with water as above. Also, present is stainless steel, carbon steel, rust in the pipe.
Just trying to pin down the source of corrosion. The chlorine shows up on some of the new nickel discs also.
By in large, the nickel discs are trouble free except for a few unexplained installations. Bad batch of nickel discs?
Any help appreciated.
