run abaqus script
mustapha1234
FR
hello,
I tried to run an abaqus script (myscript.py) using the instructions: abaqus cae script=myscript.py and abaqus viewer script=myscript.py and a get the sytaxeror:invalid syntax
I tried also to use file->run script but i get Syntax error:('unexpected character after line continuation character')
that in one hand, in auther hand i need help to tell me how i can import a Matlab file results to abaqus script.
think you
It sounds like you have a syntax error in your python script. It should give you a line number where the error is to aid in debugging.
For import matlab file results, you could try getting the SciPy package working with Abaqus (I tried, but not too hard since I didn't have long to spend on it). Alternatively, if you don't have a ton of information to pass from MATLAB to Abaqus, you can write the MATLAB results to a file (.dat, .txt, etc) and then load them in your python script using the numpy package that comes with Abaqus and the numpy.loadtxt function
you can also use python, numpy and scipy instead of matlab.
