Rubber hardness calculation
Halilcan
Materials
TR
Hi all,
How can I calculate the hardness (ShoreA) of a silicone rubber compound? I have 70 Sh and 40 Sh base rubber, peroxide catalyst, and quartz as filler. I would like to obtain 65 Sh rubber. Is there any equation to estimate the hardness before producing?
İf i would mix the same amount of 70Sh and 40Sh base rubber (let’s say 10 kg per each base) how much filler am i going to need to reach the 65 shore value?
that is no rocket science.
Most silicone bases are additive concerning hardness, chemists call it mixing cross --> 5 parts of 40 Shore and 25 parts of 70 Shore.
(5x40 + 25*70)/30 = 65
Ground quartz has quite low influence on hardness (appr. +2 pts. per 10 parts of filler). Quartz is not so healthy stuff, look for a ready batch from your silicone supplier.
Quartz reduces Tensile strength , so check your specification before.
Remark: If you mix 40 and 70 1:1, result will be 55, hence you need appr. 50 parts of quartz. It is possible, it is cheap, but it is very crumbly stuff with low mechanicals.
Peroxide: Some silicones show very different Shore A values with different peroxides and all nominal hardness values are +/-5 usually, so better test hardness of your "40" and "70" with the intended peroxide type first before calculating final hardness.
Or simply do trial and error ;-(( Let us know your results.
Good luck.
Berti
