N
notimkezkyc
Guest
I need help to model rubber bonded to steel in ProMechanica?
I hope some body can give me some tips.
Basically I have to model a 3 layers ofmaterial. The 1st layer is steel, the 2nd layer is rubber and the 3rd layer is steel. The rubber layer is bonded to the 1st and 3rd layer. I need to study the effects on the steel and rubber if multiple force loading are applied.
I need to know is there a way to assign the rubber bonding to steel, can I use weld (edge/perimeter?) and can I change the weld material properties.
Is this analysis possible in ProMechanica?
