I have a potable water bladder 20,000 liter made in rubber base material.
It has an inlet and an outlet. It lays on the ground and it shall work between -50C to 50C.
What should be the way to protect the water from freezing and / or becoming to warm to be drunk.
Is there a special material (plastic) that could be glued to the rubber bladder?
Thank you
Gore
Thank you
Gore
