Round on Surface
  • Thread starter Thread starter amd450
  • Start date Start date
A
amd450
Guest
I'm trying do a round in 2 surfaces after that I create still appearing segments that I dont want that appear, I tried use the command trim by quilt but I dont got any results.
Thanks in advance
If you created a surface Fillet then you can merge them together. Merge the first surface abd the round then merge the second surface into the first. It will automatically trim. Make sure you choose the correct sides to keep.
Use the normal round pick under the solid menu (surface - surface round) - Pro/E is smart enough to distinguish between surface surfaces and solid surfaces.
The resultant round will be a trimmed and merged quilt....
