Pipeline1972
hello everyone,
i'm working on a list of pipe materials for which i need to find the roughness values, for use in a pressure loss calculator.
I've done quite some research, including here, and i was surprised to see that:
A. It's hard to find that kind of info
B. Values are different, depending on the source
For example, in the Toolbox, I found a value for stainless steel to be 6E-4 inch, another source tells me 1.8E-3.
For PVC, i found a value of 84E-5. A supplier's source gives me 7E-5.
Anyway, I'm hoping someone could help me out finishing my list by providing me with the Ra values for (or a link to a good source):
Galvanized steel
Zinc plated steel
Cupper
And, I also have a bunch of plastic lined steel pipes. Is it correct to assume the values for the plastic to be used in the case of lined pipes?
Thanks a lot for your insights!
Process - Piping
ing - EiT
Galvanized steel
Zinc plated steel
Cupper
Process - Piping
ing - EiT
