Hi everybody,
I'm making a model that consists of three parts, two solids and one shell. I created the parts and then the assembly by using .cae interface but without move o rotate parts, in order to avoid relative coordinates in the input file.
For this reason I continued to edit my model by means the input file but a problem comes when I manipulate the coordinates of the nodes. If I exchange y column coordinates with z column of a solid part, in order to rotate the body, and If I import this in .cae interface to check contingent errors this part becomes translucent and you know that translucent body means that there is some mistakes.
I 'd like to know what I'm doing wrong in these steps, because if I do the same with a shell body no problems occurs.
Thank you for your time
Jack
Jack
