greendoor4
- May 28, 2010
- 3
How would one approach calculating the minimum diameter of a rotating shaft if:
- it is initially spinning ~1-3k rpm
- it is decelerated at any moment when a generator is activated on one side (through a clutch mechanism)
Looking through Shigley's Mechanical Design book, I came across some shaft type calculations, but it does not seem to consider anything about rotational speed/acceleration... I am not sure if that should affect anything or not.
If you have any guidance, please share.
