Rotate Plane view
Kimpan
39
I am having a problem with the plane orientation.
When hitting "normal to" on a plane, I find the sketch rotated, see image.
Is there a way to alter the plane orientation? Everytime I create a new plane, it is oriented in this rotated way which is a pain when sketching..
Turn on the Triad and the origin, that will you understand what the orientation is. I cannot tell from you image what is going on.
Scott Baugh, CSWP [pc2]
Berry Plastics
Cad Admin\Design Engineer
GEASWUG Greater Evansville Area SWUG Leader
"If it's not broke, Don't fix it!"
faq731-376
The origin and original planes are randomly placed. Its from scanned data.
Basically I want the line that is pointed to in the attached image to be horizontal when pressing "normal to" on the "middle plain".
Then u will have to rotate the sketch to match the Origin axis then the plane will probably be fine.
Berry Plastics
faq731-376
SolidWorks orients planes based on a mathematical calculation of the kernal based more on relation to origin. Because of that even a plane created by 3 points will not have it's horizontal direction between points 1 & 2. The only way to achieve the orientation you want easily is to create a sketched surface plane and even then it may not be correctly oriented. Even a 0 offset ref plane may still orient as your middle plane does. I assume you already tried making a plane through the annotated line normal to it's perpendicular one attached and one through it and at angle to that plane. If not give that a try
"It's not the size of the Forum that matters, It's the Quality of the Posts"
Michael Cole
Boston, MA
CSWP, CSWI, CSWTS
Follow me on !w¡#$%
@ TrajPar - @ mcSldWrx2008
= ProE = SolidWorks
